Salta al contenuto principale
HP Pavilion x2 10-n113dx Camera Replacement
Cosa ti serve
  1. HP Pavilion x2 10-n113dx Camera Replacement, Camera: passo 1, immagine 1 di 3 HP Pavilion x2 10-n113dx Camera Replacement, Camera: passo 1, immagine 2 di 3 HP Pavilion x2 10-n113dx Camera Replacement, Camera: passo 1, immagine 3 di 3
    • Separate the screen from the keyboard.
    • The keyboard and screen are held together via magnets.
    • Open the device and pull the screen parallel to its face.
  2. HP Pavilion x2 10-n113dx Camera Replacement: passo 2, immagine 1 di 3 HP Pavilion x2 10-n113dx Camera Replacement: passo 2, immagine 2 di 3 HP Pavilion x2 10-n113dx Camera Replacement: passo 2, immagine 3 di 3
    • Separate the screen from body of the computer with a blue spudger.
    • Using a plastic spudger, gently begin separating the face from the body.
    • Separate each side gently.
  3. HP Pavilion x2 10-n113dx Camera Replacement: passo 3, immagine 1 di 2 HP Pavilion x2 10-n113dx Camera Replacement: passo 3, immagine 2 di 2
    • Once each edge has been separated, gently lift the face (screen) from the back.
    • Be sure to not do so quickly or you risk tearing the keyboard ribbon cable.
    • Rotate the device 180 degrees for the following steps.
  4. HP Pavilion x2 10-n113dx Camera Replacement: passo 4, immagine 1 di 2 HP Pavilion x2 10-n113dx Camera Replacement: passo 4, immagine 2 di 2
    • Follow the attached ribbon cable to the circuit board of the device.
    • On the side of the ribbon cable, use a small plastic spudger to pop open this plastic lock and gently pull in the direction of the cable to remove.
    • Gently lift up on the battery connector just below the earlier removed ribbon cable to remove.
  5. HP Pavilion x2 10-n113dx Camera Replacement: passo 5, immagine 1 di 2 HP Pavilion x2 10-n113dx Camera Replacement: passo 5, immagine 2 di 2
    • Unscrew and remove each of the four indicated screws using the Phillips #0 screwdriver.
    • Begin with the bottom left 4.5mm diameter screw.
    • Continue to the remaining three 2.0 mm diameter screws.
    • Once all four screws have been removed lift the battery from the device using the indicated pull tab along the top edge.
  6. HP Pavilion x2 10-n113dx Camera Replacement: passo 6, immagine 1 di 3 HP Pavilion x2 10-n113dx Camera Replacement: passo 6, immagine 2 di 3 HP Pavilion x2 10-n113dx Camera Replacement: passo 6, immagine 3 di 3
    • Using a small blue plastic spudger pop off the two speaker wires from the circuit board.
    • Once removed from the board carefully move the wires from the raised clips on the metal plating.
  7. HP Pavilion x2 10-n113dx Camera Replacement: passo 7, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the 4.5mm screw from the camera circuit board.
    • Using a plastic spudger flip up the two rubber covers to the right and left of the 4.5mm screw.
  8. HP Pavilion x2 10-n113dx Camera Replacement: passo 8, immagine 1 di 2 HP Pavilion x2 10-n113dx Camera Replacement: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Carefully remove the ribbon cable from the camera circuit board with tweezers.
    • Carefully remove the wire mesh tape from the metal plating using tweezers.
  9. HP Pavilion x2 10-n113dx Camera Replacement: passo 9, immagine 1 di 2 HP Pavilion x2 10-n113dx Camera Replacement: passo 9, immagine 2 di 2
    • Using a plastic spudger remove the camera circuit board from the device.
Conclusione
Cayla Skaggs
Membro da: 04/01/19
337 Reputazione
2 Guide realizzate
IUPUI, Team S1-G4, Harley Spring 2019 Membro di IUPUI, Team S1-G4, Harley Spring 2019
IUPUI-HARLEY-S19S1G4
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 459
