Salta al contenuto principale
HP Pavilion x2 10-n113dx Battery Replacement
Cosa ti serve
  1. HP Pavilion x2 10-n113dx Battery Replacement, Battery: passo 1, immagine 1 di 3 HP Pavilion x2 10-n113dx Battery Replacement, Battery: passo 1, immagine 2 di 3 HP Pavilion x2 10-n113dx Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx Battery Replacement: passo 2, immagine 1 di 2 HP Pavilion x2 10-n113dx Battery Replacement: passo 2, immagine 2 di 2
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx Battery Replacement: passo 3, immagine 1 di 3 HP Pavilion x2 10-n113dx Battery Replacement: passo 3, immagine 2 di 3 HP Pavilion x2 10-n113dx Battery Replacement: passo 3, immagine 3 di 3
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx Battery Replacement: passo 4, immagine 1 di 3 HP Pavilion x2 10-n113dx Battery Replacement: passo 4, immagine 2 di 3 HP Pavilion x2 10-n113dx Battery Replacement: passo 4, immagine 3 di 3
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx Battery Replacement: passo 5, immagine 1 di 3 HP Pavilion x2 10-n113dx Battery Replacement: passo 5, immagine 2 di 3 HP Pavilion x2 10-n113dx Battery Replacement: passo 5, immagine 3 di 3
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team S13-G4, Boczar Fall 2017 Membro di USF Tampa, Team S13-G4, Boczar Fall 2017
USFT-BOCZAR-F17S13G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 28
Tutti i Tempi: 5,024
