Introduzione
One of the easiest ways to speed up your computer is to add more RAM. This guide will walk you through how to replace the RAM in your laptop.
Be sure that you buy the right type of RAM. The g7-2275 dx supports two stick of RAM, up to 8 GB. It takes 204-pin SODIMM DDR3 PC3-10600 1333MHz RAM.
For more information about RAM, check out iFixit's RAM page
Strumenti
Parti
Nessuna parte specificata.
Unscrew one Phillips #1 screw from the back panel.
Use your fingers, plastic opening tools, or pliers to pull the silver brackets away from the RAM.
Altre 2 persone hanno completato questa guida.
