Salta al contenuto principale
HP Pavilion g7-2275dx Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion g7-2275dx Hard Drive Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: passo 1, immagine 1 di 1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  2. HP Pavilion g7-2275dx Hard Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion g7-2275dx Hard Drive Replacement: passo 2, immagine 2 di 2
    • Slide the back panel down and pull it up.
  3. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 2 HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 2
    • Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive.
    • Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
    • Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
  4. HP Pavilion g7-2275dx Hard Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion g7-2275dx Hard Drive Replacement: passo 4, immagine 2 di 2
    • Gently pull up on the plastic tab attached to the hard drive.
    • Pull the hard drive up and to the right to remove it completely from the laptop.
  5. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Remove the black SATA cable from the hard drive.
  6. HP Pavilion g7-2275dx Hard Drive Replacement: passo 6, immagine 1 di 2 HP Pavilion g7-2275dx Hard Drive Replacement: passo 6, immagine 2 di 2
    • Remove the black rubber end caps.
  7. HP Pavilion g7-2275dx Hard Drive Replacement: passo 7, immagine 1 di 2 HP Pavilion g7-2275dx Hard Drive Replacement: passo 7, immagine 2 di 2
    • Remove the four silver 5 mm Phillips #1 screws from the hard drive.
  8. HP Pavilion g7-2275dx Hard Drive Replacement: passo 8, immagine 1 di 1
    • Remove the plastic cover from the hard drive.
Conclusione
To reassemble or replace your hard drive, follow these instructions in reverse order with the working drive.
Altre 5 persone hanno completato questa guida.
Erik Miller
Membro da: 04/22/14
2.123 Reputazione
4 Guide realizzate
Cal Poly, Team 11-51, Amido Spring 2014 Membro di Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 4,943
