Salta al contenuto principale
HP Pavilion g7-1368dx Keyboard Replacement
Cosa ti serve
  1. HP Pavilion g7-1368dx Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx Keyboard Replacement: passo 2, immagine 1 di 1
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: passo 3, immagine 1 di 3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: passo 3, immagine 2 di 3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
    • Slide the service panel down and pull it up to remove.
  4. HP Pavilion g7-1368dx Keyboard Replacement: passo 4, immagine 1 di 1
    • Remove the one 7 mm Phillips #1 screw securing the keyboard to the device.
  5. HP Pavilion g7-1368dx Keyboard Replacement: passo 5, immagine 1 di 1
    • Flip over the device and open the screen.
  6. HP Pavilion g7-1368dx Keyboard Replacement: passo 6, immagine 1 di 2 HP Pavilion g7-1368dx Keyboard Replacement: passo 6, immagine 2 di 2
    • Flip the keyboard over and locate the black ribbon cable that attaches the keyboard to the device.
    • Using a plastic opening tool, flip up the white tab on the zero insertion force connector.
    • Disconnect the ribbon cable by sliding it out of the ZIF connector.
    • Remove the keyboard.
Conclusione
Kianna Young
Membro da: 01/16/19
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 267
