Salta al contenuto principale
HP Pavilion g7-1368dx Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion g7-1368dx  Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx  Hard Drive Replacement: passo 2, immagine 1 di 1
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx  Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
  4. HP Pavilion g7-1368dx  Hard Drive Replacement: passo 4, immagine 1 di 1
    • Slide the service panel down and pull it up to remove.
  5. HP Pavilion g7-1368dx  Hard Drive Replacement: passo 5, immagine 1 di 2 HP Pavilion g7-1368dx  Hard Drive Replacement: passo 5, immagine 2 di 2
    • Locate the hard drive.
    • It is missing from the device pictured here.
    • Disconnect the cable connector by pulling it away from the hard drive.
    • Remove the hard drive from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 294
