Salta al contenuto principale
HP Pavilion g7-1150us Surface Panel Replacement
Cosa ti serve
  1. HP Pavilion g7-1150us Surface Panel Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion g7-1150us Surface Panel Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us Surface Panel Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us Surface Panel Replacement, Surface Panel: passo 3, immagine 1 di 1
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us Surface Panel Replacement: passo 4, immagine 1 di 2 HP Pavilion g7-1150us Surface Panel Replacement: passo 4, immagine 2 di 2
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us Surface Panel Replacement: passo 5, immagine 1 di 1
    • Lift the pried surface panel off of the computer.
Conclusione
Kyle Dinunno
Membro da: 03/20/19
377 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 266
