Salta al contenuto principale
HP Pavilion g7-1150us Optical Drive Replacement
Cosa ti serve
  1. HP Pavilion g7-1150us Optical Drive Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion g7-1150us Optical Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us Optical Drive Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us Optical Drive Replacement, Surface Panel: passo 3, immagine 1 di 1
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us Optical Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion g7-1150us Optical Drive Replacement: passo 4, immagine 2 di 2
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us Optical Drive Replacement: passo 5, immagine 1 di 1
    • Lift the pried surface panel off of the computer.
  6. HP Pavilion g7-1150us Optical Drive Replacement, Optical Drive: passo 6, immagine 1 di 1
    • Use the screwdriver to remove the 4mm Phillips #0 screw holding the optical drive in.
  7. HP Pavilion g7-1150us Optical Drive Replacement: passo 7, immagine 1 di 1
    • Use your fingers to grab the optical drive.
  8. HP Pavilion g7-1150us Optical Drive Replacement: passo 8, immagine 1 di 1
    • Pull out drive completely.
Conclusione
Cierra Sheerin
Membro da: 03/25/19
97 Reputazione
1 Guida realizzata
2 Commenti
What do you do when the DVD drive will NOT slide out? That’s my problem. There’s no disk inside; the unit is simply stuck shut. Now what do you do?
paulwrites - Replica
For me, the DVD drive connection had, what I think was soda, inside of the port and it acted like a sort of glue so brute force may be the option.
After a deep cleaning of the connections, it worked like new.
Dylan Dopp -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 434
