Salta al contenuto principale
HP Pavilion g7-1150us Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion g7-1150us Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion g7-1150us Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us Hard Drive Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us Hard Drive Replacement, Surface Panel: passo 3, immagine 1 di 1
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us Hard Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion g7-1150us Hard Drive Replacement: passo 4, immagine 2 di 2
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us Hard Drive Replacement: passo 5, immagine 1 di 1
    • Lift the pried surface panel off of the computer.
  6. HP Pavilion g7-1150us Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 1
    • Grab the hard drive gently on either side. The left side is where the hard drive is connected to the laptop.
    • The hard drive was missing from our device.
  7. HP Pavilion g7-1150us Hard Drive Replacement: passo 7, immagine 1 di 1
    • Gently pull the hard drive to the right away from the connector. When fully disconnected you have safely removed the hard drive!
Conclusione
Altre 2 persone hanno completato questa guida.
Gabriel Lurz
Membro da: 03/20/19
127 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 807
