Introduzione
To remove the laptop's speakers, many components within the laptop need to be removed. This is a guide to do so.
Cosa ti serve
Flip the computer so the bottom is facing up with the battery away from you.
Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
Use the PH 00 screwdriver to unscrew the 2.5 mm screw to the right of the hard drive.
Using a PH 00 screwdriver, remove the screw located next to the wireless card.
With the laptop bottom facing up, locate the rubber plug on the right side of the computer.
Use a metal splunger to remove the plug.
Altre 10 persone hanno completato questa guida.
2 Commenti
I Love the practical very much
HP Pavilion g6 price
