Salta al contenuto principale
HP Pavilion g6-1b79dx CD Drive Replacement
Cosa ti serve
  1. HP Pavilion g6-1b79dx CD Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx CD Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion g6-1b79dx CD Drive Replacement: passo 2, immagine 2 di 2
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx CD Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion g6-1b79dx CD Drive Replacement: passo 3, immagine 2 di 2
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx CD Drive Replacement, Bottom Panel: passo 4, immagine 1 di 1
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx CD Drive Replacement: passo 5, immagine 1 di 1
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx CD Drive Replacement: passo 6, immagine 1 di 3 HP Pavilion g6-1b79dx CD Drive Replacement: passo 6, immagine 2 di 3 HP Pavilion g6-1b79dx CD Drive Replacement: passo 6, immagine 3 di 3
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx CD Drive Replacement, CD Drive: passo 7, immagine 1 di 2 HP Pavilion g6-1b79dx CD Drive Replacement, CD Drive: passo 7, immagine 2 di 2
    • Using the PH 00 screwdriver, remove the screw left of the CD drive.
  8. HP Pavilion g6-1b79dx CD Drive Replacement: passo 8, immagine 1 di 3 HP Pavilion g6-1b79dx CD Drive Replacement: passo 8, immagine 2 di 3 HP Pavilion g6-1b79dx CD Drive Replacement: passo 8, immagine 3 di 3
    • Slide the CD drive out from the exterior of the laptop.
Conclusione
patrickhall
Membro da: 09/23/15
730 Reputazione
3 Guide realizzate
Baylor, Team 10-12, Williams Fall 2015 Membro di Baylor, Team 10-12, Williams Fall 2015
BU-WILLIAMS-F15S10G12
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 500
