Introduzione
If the bottom panel is damaged or needs to be moved to reach another component of the laptop this is a guide to remove it.
Cosa ti serve
Flip the computer so the bottom is facing up with the battery away from you.
Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
Altre 2 persone hanno completato questa guida.
