Salta al contenuto principale
HP Pavilion g4-1117dx Speaker Replacement
Cosa ti serve
  1. HP Pavilion g4-1117dx Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Speaker Replacement, L-Shaped Back Panel: passo 3, immagine 1 di 1
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
  3. HP Pavilion g4-1117dx Speaker Replacement: passo 4, immagine 1 di 1
    • Carefully pry off the L-shaped panel.
  4. HP Pavilion g4-1117dx Speaker Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Pull out and unplug the tab on the right hand side.
  5. HP Pavilion g4-1117dx Speaker Replacement, Larger Back Panel: passo 6, immagine 1 di 1
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  6. HP Pavilion g4-1117dx Speaker Replacement: passo 7, immagine 1 di 1
    • Remove 3 screws located where the battery previously was.
  7. HP Pavilion g4-1117dx Speaker Replacement: passo 8, immagine 1 di 2 HP Pavilion g4-1117dx Speaker Replacement: passo 8, immagine 2 di 2
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  8. HP Pavilion g4-1117dx Speaker Replacement: passo 9, immagine 1 di 1
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
  9. HP Pavilion g4-1117dx Speaker Replacement: passo 10, immagine 1 di 1
    • Unplug wires connecting back panel to keyboard.
  10. HP Pavilion g4-1117dx Speaker Replacement, Speaker: passo 11, immagine 1 di 2 HP Pavilion g4-1117dx Speaker Replacement, Speaker: passo 11, immagine 2 di 2
    • Unplug the red and white wires.
  11. HP Pavilion g4-1117dx Speaker Replacement: passo 12, immagine 1 di 1
    • Remove the speakers.
Conclusione
Robert Hamilton
Membro da: 03/01/18
1.165 Reputazione
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 601
