Introduzione
When keyboards become worn or unresponsive, it's typically time to replace them. Replacing a keyboard can be especially difficult, as it's normally secured by many screws. This guide outlines all the steps needed to access the keyboard.
Cosa ti serve
Turn the laptop over to expose the bottom side.
Locate the battery removal switch next to the battery compartment
Slide the switch all the way to the left to release the battery. The battery should pop up.
Lift the battery out.
Remove the six 5 mm screws in the battery compartment using Phillips #1 screwdriver.
Remove the 7mm keyboard screw located towards the center of the laptop with a Phillips #1 screwdriver.
1Commento della guida
Please I have a problem with my hp laptop the keyboard and there is noise on it, repair it automatic. thanks you
