Salta al contenuto principale
HP Pavilion dv9000 Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion dv9000 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Hard Drive Replacement, Battery Removal: passo 2, immagine 1 di 2 HP Pavilion dv9000 Hard Drive Replacement, Battery Removal: passo 2, immagine 2 di 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • There are two hard drive bays.
    • Hard drive bay 1 is in the lower right corner.
    • Hard drive bay 2 is in the lower left corner.
  4. HP Pavilion dv9000 Hard Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion dv9000 Hard Drive Replacement: passo 4, immagine 2 di 2
    • To remove hard drive 1 from bay 1
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws that hold the bay 1 cover in place.
    • The screws should remain in the cover.
  5. HP Pavilion dv9000 Hard Drive Replacement: passo 5, immagine 1 di 2 HP Pavilion dv9000 Hard Drive Replacement: passo 5, immagine 2 di 2
    • After removing the two cover screws, lift and slide the cover out of position to access the hard drive.
    • Grab the clear plastic pull tab on top of the hard drive to lift the hard drive from the laptop.
  6. HP Pavilion dv9000 Hard Drive Replacement: passo 6, immagine 1 di 3 HP Pavilion dv9000 Hard Drive Replacement: passo 6, immagine 2 di 3 HP Pavilion dv9000 Hard Drive Replacement: passo 6, immagine 3 di 3
    • To remove hard drive 2 from bay 2.
    • Most laptops don't have a second hard drive. If yours does not, then proceed to the next step.
    • Using a Phillips #1 screwdriver remove the two 5 mm screws that hold the bay 2 cover in place.
    • Grab the clear plastic pull tab on top of the hard drive, and lift the hard drive from the laptop.
  7. HP Pavilion dv9000 Hard Drive Replacement: passo 7, immagine 1 di 3 HP Pavilion dv9000 Hard Drive Replacement: passo 7, immagine 2 di 3 HP Pavilion dv9000 Hard Drive Replacement: passo 7, immagine 3 di 3
    • After the hard drive has been removed from the laptop, it must then be removed from its bracket.
    • Start by gently pulling the HP hard drive adapter from the end of the hard drive.
    • Using a Phillips #1 screwdriver, remove the four 3 mm bracketing screws on both sides of the hard drive bracket (2 per side) .
    • Lift the hard drive from its metal bracket.
    • Be careful not to touch the green underside as this may damage the hard drive.
Conclusione
Altre 8 persone hanno completato questa guida.
Robby Cabri
Membro da: 01/23/14
178 Reputazione
1 Guida realizzata
Cal Poly, Team 10-32, Maness Winter 2014 Membro di Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Membri
6 Guide realizzate
4 Commenti
Hello. In step 7 of the above, what is the name/part number/ size etc of the adapter/connector please ? I need one urgently.
Thanks.
freeflyshannon - Replica
yes that would be very helpfull because the new SSdrive I have will not fit even though is is the same size. I think I need some sort of an adaptor as you say.
Stephen Cox - Replica
For modern SATA SSDs, the typical form factor is 7.5mm. The standard for laptop HDDs is 9.5mm. You will need to buy a plastic spacer in order to properly mount the drive inside your computer.
Michael - Replica
thanks for the help
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 21
Tutti i Tempi: 8,994
