Salta al contenuto principale
HP Pavilion dv7t-7000 Palm Rest Replacement
Cosa ti serve
  1. HP Pavilion dv7t-7000 Palm Rest Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Palm Rest Replacement: passo 2, immagine 1 di 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Palm Rest Replacement: passo 3, immagine 1 di 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Palm Rest Replacement, Back Panel: passo 4, immagine 1 di 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Palm Rest Replacement: passo 5, immagine 1 di 2 HP Pavilion dv7t-7000 Palm Rest Replacement: passo 5, immagine 2 di 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Palm Rest Replacement, RAM: passo 6, immagine 1 di 2 HP Pavilion dv7t-7000 Palm Rest Replacement, RAM: passo 6, immagine 2 di 2
    • Push the retraining springs away from the RAM at the same time to unlock the RAM.
  7. HP Pavilion dv7t-7000 Palm Rest Replacement: passo 7, immagine 1 di 2 HP Pavilion dv7t-7000 Palm Rest Replacement: passo 7, immagine 2 di 2
    • Pull the RAM out.
    • Follow the same procedure for the additional RAM.
  8. HP Pavilion dv7t-7000 Palm Rest Replacement, Wi-Fi Card: passo 8, immagine 1 di 2 HP Pavilion dv7t-7000 Palm Rest Replacement, Wi-Fi Card: passo 8, immagine 2 di 2
    • Use the flat end of a spudger to pop off the antenna connectors.
  9. HP Pavilion dv7t-7000 Palm Rest Replacement: passo 9, immagine 1 di 3 HP Pavilion dv7t-7000 Palm Rest Replacement: passo 9, immagine 2 di 3 HP Pavilion dv7t-7000 Palm Rest Replacement: passo 9, immagine 3 di 3
    • Remove single Phillips #00 screw.
    • Pull the card out by hand.
  10. HP Pavilion dv7t-7000 Palm Rest Replacement, Keyboard: passo 10, immagine 1 di 2 HP Pavilion dv7t-7000 Palm Rest Replacement, Keyboard: passo 10, immagine 2 di 2
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  11. HP Pavilion dv7t-7000 Palm Rest Replacement: passo 11, immagine 1 di 3 HP Pavilion dv7t-7000 Palm Rest Replacement: passo 11, immagine 2 di 3 HP Pavilion dv7t-7000 Palm Rest Replacement: passo 11, immagine 3 di 3
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  12. HP Pavilion dv7t-7000 Palm Rest Replacement: passo 12, immagine 1 di 1
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  13. HP Pavilion dv7t-7000 Palm Rest Replacement, Palm Rest: passo 13, immagine 1 di 3 HP Pavilion dv7t-7000 Palm Rest Replacement, Palm Rest: passo 13, immagine 2 di 3 HP Pavilion dv7t-7000 Palm Rest Replacement, Palm Rest: passo 13, immagine 3 di 3
    • Flip the keyboard back over.
    • Remove the single Phillips #00 screw holding in the CD drive.
    • Pull out the CD drive.
  14. HP Pavilion dv7t-7000 Palm Rest Replacement: passo 14, immagine 1 di 1
    • Remove the seventeen Phillips #00 screws securing the back panel to the laptop.
  15. HP Pavilion dv7t-7000 Palm Rest Replacement: passo 15, immagine 1 di 2 HP Pavilion dv7t-7000 Palm Rest Replacement: passo 15, immagine 2 di 2
  16. HP Pavilion dv7t-7000 Palm Rest Replacement: passo 16, immagine 1 di 1
    • Remove the panel by lifting it up.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 277
