Salta al contenuto principale
HP Pavilion dv7t-7000 Motherboard Replacement
Cosa ti serve
  1. HP Pavilion dv7t-7000 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Motherboard Replacement: passo 2, immagine 1 di 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Motherboard Replacement: passo 3, immagine 1 di 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Motherboard Replacement, Back Panel: passo 4, immagine 1 di 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Motherboard Replacement: passo 5, immagine 1 di 2 HP Pavilion dv7t-7000 Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Motherboard Replacement, Keyboard: passo 6, immagine 1 di 2 HP Pavilion dv7t-7000 Motherboard Replacement, Keyboard: passo 6, immagine 2 di 2
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  7. HP Pavilion dv7t-7000 Motherboard Replacement: passo 7, immagine 1 di 3 HP Pavilion dv7t-7000 Motherboard Replacement: passo 7, immagine 2 di 3 HP Pavilion dv7t-7000 Motherboard Replacement: passo 7, immagine 3 di 3
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
    The keyboard on mine had retaining studs on the palm rest side. Removing according to these directions broke the keyboard.
    Some keyboards may not have these.
    Peter K - Replica
  8. HP Pavilion dv7t-7000 Motherboard Replacement: passo 8, immagine 1 di 1
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  9. HP Pavilion dv7t-7000 Motherboard Replacement, RAM: passo 9, immagine 1 di 2 HP Pavilion dv7t-7000 Motherboard Replacement, RAM: passo 9, immagine 2 di 2
    • Push the retraining springs away from the RAM at the same time to unlock the RAM.
  10. HP Pavilion dv7t-7000 Motherboard Replacement: passo 10, immagine 1 di 2 HP Pavilion dv7t-7000 Motherboard Replacement: passo 10, immagine 2 di 2
    • Pull the RAM out.
    • Follow the same procedure for the additional RAM.
  11. HP Pavilion dv7t-7000 Motherboard Replacement, Wi-Fi Card: passo 11, immagine 1 di 2 HP Pavilion dv7t-7000 Motherboard Replacement, Wi-Fi Card: passo 11, immagine 2 di 2
    • Use the flat end of a spudger to pop off the antenna connectors.
  12. HP Pavilion dv7t-7000 Motherboard Replacement: passo 12, immagine 1 di 3 HP Pavilion dv7t-7000 Motherboard Replacement: passo 12, immagine 2 di 3 HP Pavilion dv7t-7000 Motherboard Replacement: passo 12, immagine 3 di 3
    • Remove single Phillips #00 screw.
    • Pull the card out by hand.
  13. HP Pavilion dv7t-7000 Motherboard Replacement, Palm Rest: passo 13, immagine 1 di 3 HP Pavilion dv7t-7000 Motherboard Replacement, Palm Rest: passo 13, immagine 2 di 3 HP Pavilion dv7t-7000 Motherboard Replacement, Palm Rest: passo 13, immagine 3 di 3
    • Flip the keyboard back over.
    • Remove the single Phillips #00 screw holding in the CD drive.
    • Pull out the CD drive.
  14. HP Pavilion dv7t-7000 Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove the seventeen Phillips #00 screws securing the back panel to the laptop.
  15. HP Pavilion dv7t-7000 Motherboard Replacement: passo 15, immagine 1 di 2 HP Pavilion dv7t-7000 Motherboard Replacement: passo 15, immagine 2 di 2
  16. HP Pavilion dv7t-7000 Motherboard Replacement: passo 16, immagine 1 di 1
    • Remove the panel by lifting it up.
  17. HP Pavilion dv7t-7000 Motherboard Replacement, Motherboard: passo 17, immagine 1 di 1
    • Remove the eleven Phillips #00 screws.
  18. HP Pavilion dv7t-7000 Motherboard Replacement: passo 18, immagine 1 di 3 HP Pavilion dv7t-7000 Motherboard Replacement: passo 18, immagine 2 di 3 HP Pavilion dv7t-7000 Motherboard Replacement: passo 18, immagine 3 di 3
    • Use the flat end of a spudger to disconnect all wires connected to the motherboard.
  19. HP Pavilion dv7t-7000 Motherboard Replacement: passo 19, immagine 1 di 2 HP Pavilion dv7t-7000 Motherboard Replacement: passo 19, immagine 2 di 2
    • Lift up the black tab on the ZIF connector with the flat end of a spudger.
    • Pull the ribbon cable out of the ZIF connector.
    • Remove the fan from the laptop.
Conclusione
Un commento
Hello guys
I'm searching for a Bottom Base Case for HP Envy DV7 Pavilion
Does anyone know where to find it?
Ri Ma - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,144
