Salta al contenuto principale
HP Pavilion dv7t-7000 Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion dv7t-7000 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Hard Drive Replacement, Back Panel: passo 4, immagine 1 di 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 5, immagine 1 di 2 HP Pavilion dv7t-7000 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 1
    • Remove the two Phillips #00 screws holding in the hard drive.
  7. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 7, immagine 1 di 2 HP Pavilion dv7t-7000 Hard Drive Replacement: passo 7, immagine 2 di 2
    • Grab the black tab on the hard drive and pull left and then upwards to remove.
  8. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 8, immagine 1 di 1
    • Remove the four Phillips #00 screws holding the hard drive to its case.
  9. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 9, immagine 1 di 2 HP Pavilion dv7t-7000 Hard Drive Replacement: passo 9, immagine 2 di 2
    • Slide the casing off of the hard drive.
  10. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 10, immagine 1 di 1
    • Unplug the hard drive from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 404
