Salta al contenuto principale
HP Pavilion dv7t-7000 CD Drive Replacement
Cosa ti serve
  1. HP Pavilion dv7t-7000 CD Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 CD Drive Replacement: passo 2, immagine 1 di 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 CD Drive Replacement: passo 3, immagine 1 di 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 CD Drive Replacement, Back Panel: passo 4, immagine 1 di 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 CD Drive Replacement: passo 5, immagine 1 di 2 HP Pavilion dv7t-7000 CD Drive Replacement: passo 5, immagine 2 di 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 CD Drive Replacement, CD Drive: passo 6, immagine 1 di 2 HP Pavilion dv7t-7000 CD Drive Replacement, CD Drive: passo 6, immagine 2 di 2
    • Remove the single Phillips #00 screw.
  7. HP Pavilion dv7t-7000 CD Drive Replacement: passo 7, immagine 1 di 2 HP Pavilion dv7t-7000 CD Drive Replacement: passo 7, immagine 2 di 2
    • Pull CD drive out to remove.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 151
