Salta al contenuto principale
HP Pavilion dv7-6178us RAM Replacement
  1. HP Pavilion dv7-6178us RAM Replacement, RAM: passo 1, immagine 1 di 2 HP Pavilion dv7-6178us RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us RAM Replacement: passo 2, immagine 1 di 1
    • Locate the RAM and push the two tabs on the sides away from the RAM.
  3. HP Pavilion dv7-6178us RAM Replacement: passo 3, immagine 1 di 1
    • Once the tabs on the sides are released the RAM card will pop out by itself to this angle, as shown in the picture.
  4. HP Pavilion dv7-6178us RAM Replacement: passo 4, immagine 1 di 1
    • Pull the card out of the socket and you have successfully removed one RAM card.
  5. HP Pavilion dv7-6178us RAM Replacement: passo 5, immagine 1 di 2 HP Pavilion dv7-6178us RAM Replacement: passo 5, immagine 2 di 2
    • Steps 2 through 4 can also be done on the second RAM card, located directly below the initial RAM card.
Conclusione
Branden Simas
Membro da: 10/20/18
178 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 659
