Salta al contenuto principale
HP Pavilion dv7-6178us Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us Hard Drive Replacement: passo 2, immagine 1 di 1
    • Now, with the back piece off, you will remove the four screws holding it in place. Use a Phillips head screwdriver.
    • Take note of where you place the screws because you will need them for later.
  3. HP Pavilion dv7-6178us Hard Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion dv7-6178us Hard Drive Replacement: passo 3, immagine 2 di 2
    • Place the old hard drive off to the side (as seen in photo) and carefully remove the SATA cable from laptop.
    • Be careful to not damage the laptop or cable when doing this step. A gentle pull should do the trick.
Conclusione
Altre 2 persone hanno completato questa guida.
Zach Lunghi
Membro da: 10/19/18
148 Reputazione
1 Guida realizzata
Un commento
This is a really GREAT thing that's being done!
It's high time that consumers fought back and stop letting the TECHNO-OVERLORDS, collectively STRIP us of the right to use the digital tools that we purchase from them.
Walter D Wormack - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,032
