Salta al contenuto principale
HP Pavilion dv7-6178us CD Drive Replacement
Cosa ti serve
  1. HP Pavilion dv7-6178us CD Drive Replacement, CD Drive: passo 1, immagine 1 di 1
    • Make sure the device is turned off.
    • Remove the panel on the bottom of the laptop by sliding the switch to the right.
  2. HP Pavilion dv7-6178us CD Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion dv7-6178us CD Drive Replacement: passo 2, immagine 2 di 2
    • Locate the screw that keeps the CD drive attached, and remove it with a Phillips head screwdriver.
  3. HP Pavilion dv7-6178us CD Drive Replacement: passo 3, immagine 1 di 3 HP Pavilion dv7-6178us CD Drive Replacement: passo 3, immagine 2 di 3 HP Pavilion dv7-6178us CD Drive Replacement: passo 3, immagine 3 di 3
    • After the screw is removed, pry the CD drive out of the laptop until you can grip and remove it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 226
