Salta al contenuto principale
HP Pavilion dv7-4285dx Keyboard Replacement
Cosa ti serve
  1. HP Pavilion dv7-4285dx Keyboard  Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion dv7-4285dx Keyboard  Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery release switch to the left. The battery pack will then subsequently release.
  2. HP Pavilion dv7-4285dx Keyboard  Replacement: passo 2, immagine 1 di 1
    • Remove the battery pack from the socket.
  3. HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: passo 3, immagine 1 di 3 HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: passo 3, immagine 2 di 3 HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: passo 3, immagine 3 di 3
    • Unscrew the 5 black plate screws using a Ph#0 screwdriver.
    • During the removal process, the back plate will retain the 5 back plate screws.
    • Use a metal spudger to carefully remove back plate.
  4. HP Pavilion dv7-4285dx Keyboard  Replacement: passo 4, immagine 1 di 1
    • Unscrew the 7.2mm screws using a Ph#0 screwdriver.
  5. HP Pavilion dv7-4285dx Keyboard  Replacement: passo 5, immagine 1 di 2 HP Pavilion dv7-4285dx Keyboard  Replacement: passo 5, immagine 2 di 2
    • Push the keyboard release switch using the metal spudger.
  6. HP Pavilion dv7-4285dx Keyboard  Replacement: passo 6, immagine 1 di 2 HP Pavilion dv7-4285dx Keyboard  Replacement: passo 6, immagine 2 di 2
    • Lift up keyboard from its resting position.
  7. HP Pavilion dv7-4285dx Keyboard  Replacement: passo 7, immagine 1 di 3 HP Pavilion dv7-4285dx Keyboard  Replacement: passo 7, immagine 2 di 3 HP Pavilion dv7-4285dx Keyboard  Replacement: passo 7, immagine 3 di 3
    • Lift up black tab holding ribbon cable.
    • Remove ribbon cable from motherboard.
  8. HP Pavilion dv7-4285dx Keyboard  Replacement: passo 8, immagine 1 di 1
    • Remove keyboard.
Conclusione
Austin Sandel
Membro da: 11/05/18
363 Reputazione
3 Guide realizzate
IUPUI, Team S1-G2, Baechle Fall 2018 Membro di IUPUI, Team S1-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G2
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 434
