Salta al contenuto principale
HP Pavilion dv7-1448dx RAM Replacement
Cosa ti serve
  1. HP Pavilion dv7-1448dx RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the computer is unplugged and turned off.
    • Place the computer front side down with the battery compartment farthest away.
  2. HP Pavilion dv7-1448dx RAM Replacement: passo 2, immagine 1 di 2 HP Pavilion dv7-1448dx RAM Replacement: passo 2, immagine 2 di 2
    • Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
  3. HP Pavilion dv7-1448dx RAM Replacement: passo 3, immagine 1 di 2 HP Pavilion dv7-1448dx RAM Replacement: passo 3, immagine 2 di 2
    • Lightly pry the battery upward to remove.
    • When reinserting the battery, match the latches along the backside of the battery with the corresponding slots in the computer in order to press it into place.
  4. HP Pavilion dv7-1448dx RAM Replacement, RAM: passo 4, immagine 1 di 3 HP Pavilion dv7-1448dx RAM Replacement, RAM: passo 4, immagine 2 di 3 HP Pavilion dv7-1448dx RAM Replacement, RAM: passo 4, immagine 3 di 3
    • Remove the six Phillips PM2.5X6.0 screws with a Phillips #00 screwdriver.
    • Pry the back casing up and away from the rest of the laptop with the plastic opening tool.
  5. HP Pavilion dv7-1448dx RAM Replacement: passo 5, immagine 1 di 3 HP Pavilion dv7-1448dx RAM Replacement: passo 5, immagine 2 di 3 HP Pavilion dv7-1448dx RAM Replacement: passo 5, immagine 3 di 3
    • Remove the green RAM by prying it upward and pulling it away from its slot.
Conclusione
Baylor, Team 3-5, Whitney Spring 2017 Membro di Baylor, Team 3-5, Whitney Spring 2017
BU-WHITNEY-S17S3G5
2 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 9
Tutti i Tempi: 361
