Salta al contenuto principale
HP Pavilion dv7-1448dx Key Replacement
Cosa ti serve
  1. HP Pavilion dv7-1448dx Key Replacement, Key: passo 1, immagine 1 di 1
    • Make sure the computer is unplugged and turned off.
    • Open the laptop so that the keyboard is fully exposed.
  2. HP Pavilion dv7-1448dx Key Replacement: passo 2, immagine 1 di 1
    • Place the plastic opening tool in the crevice near the key that needs to be removed.
    • This works best if the tool is placed at the top of the key.
  3. HP Pavilion dv7-1448dx Key Replacement: passo 3, immagine 1 di 1
    • Gently lever the tool downward until the key tilts upward.
    • At this point, move the tool around in order to completely pry the key off the keyboard. As the key is removed, small pops will be heard.
    • This step may take longer for larger keys.
    • When reinserting the key, gently press down until 2 clicks are heard (4 for larger keys).
  4. HP Pavilion dv7-1448dx Key Replacement: passo 4, immagine 1 di 1
    • Carefully remove the key from the base.
  5. HP Pavilion dv7-1448dx Key Replacement: passo 5, immagine 1 di 1
    • If the issue is a sticky key, make sure to clean the area once it is removed.
    • Use a cotton swab with alcohol to clean the underside of the key and the key slot.
Conclusione
Baylor, Team 3-5, Whitney Spring 2017 Membro di Baylor, Team 3-5, Whitney Spring 2017
BU-WHITNEY-S17S3G5
2 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 441
