Salta al contenuto principale
HP Pavilion dv7-1448dx Battery Replacement
  1. HP Pavilion dv7-1448dx Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the computer is unplugged and turned off.
    • Place the computer front side down with the battery compartment farthest away.
  2. HP Pavilion dv7-1448dx Battery Replacement: passo 2, immagine 1 di 2 HP Pavilion dv7-1448dx Battery Replacement: passo 2, immagine 2 di 2
    • Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
  3. HP Pavilion dv7-1448dx Battery Replacement: passo 3, immagine 1 di 2 HP Pavilion dv7-1448dx Battery Replacement: passo 3, immagine 2 di 2
    • Lightly pry the battery upward to remove.
    • When reinserting the battery, match the latches along the backside of the battery with the corresponding slots in the computer in order to press it into place.
Conclusione
To reinsert a new battery, follow these instructions in reverse order.
Baylor, Team 3-5, Whitney Spring 2017 Membro di Baylor, Team 3-5, Whitney Spring 2017
BU-WHITNEY-S17S3G5
2 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 275
