Salta al contenuto principale
HP Pavilion dv7-1285dx RAM Replacement
Cosa ti serve
  1. HP Pavilion dv7-1285dx RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx RAM Replacement, Back Plate: passo 2, immagine 1 di 1
    • Locate and remove the six Phillips PM2.5ร—7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx RAM Replacement: passo 3, immagine 1 di 2 HP Pavilion dv7-1285dx RAM Replacement: passo 3, immagine 2 di 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx RAM Replacement, RAM: passo 4, immagine 1 di 1
    • Rotate the device 90 degrees to the left.
  5. HP Pavilion dv7-1285dx RAM Replacement: passo 5, immagine 1 di 3 HP Pavilion dv7-1285dx RAM Replacement: passo 5, immagine 2 di 3 HP Pavilion dv7-1285dx RAM Replacement: passo 5, immagine 3 di 3
    • Locate the grey clips on the side of the RAM and pull the grey clips away from the RAM using the plastic opening tool.
  6. HP Pavilion dv7-1285dx RAM Replacement: passo 6, immagine 1 di 3 HP Pavilion dv7-1285dx RAM Replacement: passo 6, immagine 2 di 3 HP Pavilion dv7-1285dx RAM Replacement: passo 6, immagine 3 di 3
    • Unplug the RAM.
    • Repeat step 6 to remove the second piece of RAM.
  7. HP Pavilion dv7-1285dx RAM Replacement: passo 7, immagine 1 di 2 HP Pavilion dv7-1285dx RAM Replacement: passo 7, immagine 2 di 2
    • These steps are important in the replacement of the RAM, they will assist in ensuring the device is not damaged.
    • Align the notch in the new RAM with the peg on the plug
    • Ensure the RAM is fully inserted into the plug at a 45 degree angle such that the notch of the RAM lines up with the peg on the plug
  8. HP Pavilion dv7-1285dx RAM Replacement: passo 8, immagine 1 di 2 HP Pavilion dv7-1285dx RAM Replacement: passo 8, immagine 2 di 2
    • Push down gently on the RAM until the grey clips click.
    • Repeat steps 7 and 8 to replace the second piece of RAM.
Conclusione
Cal Poly, Team 12-34, Maness Spring 2014 Membro di Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,147
