Salta al contenuto principale
HP Pavilion dv7-1285dx Keyboard Replacement
Cosa ti serve
  1. HP Pavilion dv7-1285dx Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: passo 2, immagine 1 di 2 HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: passo 2, immagine 2 di 2
    • Using a Phillips Screwdriver, remove the four Phillips M25x3.0 head screws.
  3. HP Pavilion dv7-1285dx Keyboard Replacement: passo 3, immagine 1 di 2 HP Pavilion dv7-1285dx Keyboard Replacement: passo 3, immagine 2 di 2
    • Using a plastic opening tool on both the left and right sides to remove the upper portion of the top plate.
    • Orient the device such that itโ€™s partially opened (a little less than a 45 degree angle) and the hinge faces up.
  4. HP Pavilion dv7-1285dx Keyboard Replacement: passo 4, immagine 1 di 2 HP Pavilion dv7-1285dx Keyboard Replacement: passo 4, immagine 2 di 2
    • Orient the laptop so the screen is open and facing you.
    • Grasp the top plate near the hinge and pull up.
    • This should expose a white ribbon cable.
  5. HP Pavilion dv7-1285dx Keyboard Replacement: passo 5, immagine 1 di 2 HP Pavilion dv7-1285dx Keyboard Replacement: passo 5, immagine 2 di 2
    • Locate the dark grey slide on the sides of the ribbon cable plug.
    • Using the plastic opening tool, push both sides of the dark gray slide towards the screen of the computer.
    • Unplug the ribbon cable and set the top plate aside.
  6. HP Pavilion dv7-1285dx Keyboard Replacement: passo 6, immagine 1 di 2 HP Pavilion dv7-1285dx Keyboard Replacement: passo 6, immagine 2 di 2
    • Locate the four Phillips M2.0x2 head screws at the top of the keyboard and remove them.
    • Gently lift the keyboard up from the screen side and pull the keyboard towards the screen.
  7. HP Pavilion dv7-1285dx Keyboard Replacement: passo 7, immagine 1 di 3 HP Pavilion dv7-1285dx Keyboard Replacement: passo 7, immagine 2 di 3 HP Pavilion dv7-1285dx Keyboard Replacement: passo 7, immagine 3 di 3
    • Locate the black ribbon cable attaching the keyboard to the computer.
    • Find the grey slides on the side of the ribbon cable plug.
    • Use the plastic opening tool to move the grey slides toward the screen.
    • Unplug the black ribbon cable.
    • Remove the keyboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 12-34, Maness Spring 2014 Membro di Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,885
