Salta al contenuto principale
HP Pavilion dv7-1285dx Back Plate Replacement
Cosa ti serve
  1. HP Pavilion dv7-1285dx Back Plate Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Back Plate Replacement, Back Plate: passo 2, immagine 1 di 1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Back Plate Replacement: passo 3, immagine 1 di 2 HP Pavilion dv7-1285dx Back Plate Replacement: passo 3, immagine 2 di 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
Conclusione
Chris Apple
Membro da: 04/14/14
239 Reputazione
2 Guide realizzate
Cal Poly, Team 12-34, Maness Spring 2014 Membro di Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,609
