Salta al contenuto principale
HP Pavilion dv6t-1200 Disk Tray Replacement
Cosa ti serve
  1. HP Pavilion dv6t-1200 Disk Tray Replacement, Disk Tray: passo 1, immagine 1 di 2 HP Pavilion dv6t-1200 Disk Tray Replacement, Disk Tray: passo 1, immagine 2 di 2
    • Locate the small hole on the right side of the disk tray next to the button.
  2. HP Pavilion dv6t-1200 Disk Tray Replacement: passo 2, immagine 1 di 2 HP Pavilion dv6t-1200 Disk Tray Replacement: passo 2, immagine 2 di 2
    • Extend the paper clip into a straight line and insert it into the disk tray hole located next to the release button.
    • When the disk tray is removed, make sure to clean the general area with canned air.
  3. HP Pavilion dv6t-1200 Disk Tray Replacement: passo 3, immagine 1 di 1
    • Flip the laptop to the other side and remove the four screws on the bottom of the disk tray using a Phillips #0 screwdriver.
  4. HP Pavilion dv6t-1200 Disk Tray Replacement: passo 4, immagine 1 di 2 HP Pavilion dv6t-1200 Disk Tray Replacement: passo 4, immagine 2 di 2
    • Remove the metal plate and locate the bottom right tool for the disk tray.
  5. HP Pavilion dv6t-1200 Disk Tray Replacement: passo 5, immagine 1 di 2 HP Pavilion dv6t-1200 Disk Tray Replacement: passo 5, immagine 2 di 2
    • Replace the motor piece that is being held and reclose the device.
  6. HP Pavilion dv6t-1200 Disk Tray Replacement: passo 6, immagine 1 di 2 HP Pavilion dv6t-1200 Disk Tray Replacement: passo 6, immagine 2 di 2
    • After replacing the motor and the placing the metal tray apply a good amount of WD40.
    • Once all completed the disk tray should be working smoothly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 288
