Introduzione
This is for if you need to get into the guts of the HP Pavilion dv6700. Be sure to have the anti-static strap on, as you will be coming into contact with circuitry and could permanently damage the pieces with static electricity.
Cosa ti serve
Flip over the device so that the bottom is facing you.
Locate the battery on the bottom of your laptop.
Unscrew the black screw in the top right corner using the Phillips #00 screwdriver.
Pull up on the top piece and remove it.
Lift up and out the motherboard.
Detach the connector under the motherboard.
Remove the motherboard.
come si fà a pulire o stappare le canaline in rame di raffreddamento del processore?
To clean, use cotton or cotton swabs with isopropyl alcohol. Be sure to let it fully dry before putting back together.
Google translate English to Italian: Per pulire, utilizzare cotton o cotton fioc con alcol isopropilico. Assicurati di lasciarlo asciugare completamente prima di rimontarlo.
I do not believe that they are.
Altre 8 persone hanno completato questa guida.
2 Commenti
Thank you for all your help . Very decent of you.
Spot on guide and detail.
Ian, Poynton< Cheshire
UK.
