Salta al contenuto principale
HP Pavilion dv6000 Wireless Card Replacement
Cosa ti serve
  1. HP Pavilion dv6000 Wireless Card Replacement, Wireless Card: passo 1, immagine 1 di 1
    • Lay the laptop on a flat surface, battery side up.
    • Remove the two screws securing the RAM shield to the lower case.
    • The screws will remain captive within the shield.
    • Lift and remove the RAM shield up from the lower case.
  2. HP Pavilion dv6000 Wireless Card Replacement: passo 2, immagine 1 di 2 HP Pavilion dv6000 Wireless Card Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of tweezers to disconnect both antennas from their sockets on the wireless card.
    • Be careful to pull on the contacts and not the wires. The crimps used to hold them to the wires are delicate.
  3. HP Pavilion dv6000 Wireless Card Replacement: passo 3, immagine 1 di 1
    • Remove the two 3.7 mm Phillips screws securing the wireless card to the motherboard.
    • Upon removing the Phillips screws that secures the wireless card to the motherboard, the wireless card board should pop up from its top side.
    • Grasp the wireless card and pull it straight out of its socket on the motherboard.
  4. HP Pavilion dv6000 Wireless Card Replacement: passo 4, immagine 1 di 1
    • Wireless card remains.
Conclusione
Altre 5 persone hanno completato questa guida.
Ben Hirsch
Membro da: 10/05/10
3.841 Reputazione
10 Guide realizzate
Cal Poly, Team 21-33, Regan Fall 2010 Membro di Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 26,715
