Salta al contenuto principale
HP Pavilion dv6000 Keyboard Replacement
Cosa ti serve
  1. HP Pavilion dv6000 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 HP Pavilion dv6000 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Remove the battery from the back of the computer.
    • Remove the two 7.2mm screws underneath holding the keyboard in.
    • Use a Phillips screwdriver to remove the three screws in the battery well.
  2. HP Pavilion dv6000 Keyboard Replacement, Loosen the keyboard: passo 2, immagine 1 di 3 HP Pavilion dv6000 Keyboard Replacement, Loosen the keyboard: passo 2, immagine 2 di 3 HP Pavilion dv6000 Keyboard Replacement, Loosen the keyboard: passo 2, immagine 3 di 3
    • Use a Phillips screwdriver to remove the two screws securing the RAM door.
    • Lift and remove the RAM door.
    • Use a Phillips screwdriver to remove the screw securing the keyboard to the laptop.
  3. HP Pavilion dv6000 Keyboard Replacement: passo 3, immagine 1 di 3 HP Pavilion dv6000 Keyboard Replacement: passo 3, immagine 2 di 3 HP Pavilion dv6000 Keyboard Replacement: passo 3, immagine 3 di 3
    • Flip the laptop back over (keyboard side up).
    • Pop the bezel off of the case by reaching underneath it.
    • Carefully remove the three ribbons underneath the bezel which attach it to the computer.
  4. HP Pavilion dv6000 Keyboard Replacement: passo 4, immagine 1 di 2 HP Pavilion dv6000 Keyboard Replacement: passo 4, immagine 2 di 2
    • Gently lift the keyboard out of the casing by holding the top edge (as shown). Be careful to keep the lower edge of the keyboard in place as you lift because there is a ribbon attached to the back (marked in red).
    • The keyboard is held in by six small tabs (2 on the top and 4 on the bottom). Lifting the bevel frees the top two. Free the bottom four tabs by sliding the keyboard forward towards the screen.
    There is an other screw to remove under the memory cover to allow the removing of the keyboard.
    Antonio Grilli - Replica
  5. HP Pavilion dv6000 Keyboard Replacement: passo 5, immagine 1 di 2 HP Pavilion dv6000 Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the ribbon from the computer by pulling straight back (away from the track pad and towards the monitor).
  6. HP Pavilion dv6000 Keyboard Replacement: passo 6, immagine 1 di 1
    • DONE!
Conclusione
Altre 10 persone hanno completato questa guida.
Ben Hirsch
Membro da: 10/05/10
3.826 Reputazione
10 Guide realizzate
Cal Poly, Team 21-33, Regan Fall 2010 Membro di Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Membri
12 Guide realizzate
3 Commenti
Actually, there are three screws in the step 1.
The third one is hidden under the cover for the memory box!!!
Be careful, otherwise the dammage is granted.
harley029 - Replica
Actually I was able to remove the keyboard fairly easily following the steps provided. However even after quite a few attempts at replacing it with either the new one I purchased or even the old one I am still unable to secure the data ribbon into the appropriate connector.therefore the keyboard is not functional… HELP!!! PLEASE??
James Osment - Replica
You need probably put flat cable under the plastic connector and push small plastic in. First I put cable on top and it doesn’t work.
But the easier is to unscrew tree additional screws in battery compartment and not disconnect cables.
Pawel -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 25,426
