Salta al contenuto principale
HP Pavilion dv6-6180us Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion dv6-6180us Hard Drive  Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Turn off and unplug the device before starting.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion dv6-6180us Hard Drive  Replacement: passo 2, immagine 1 di 1
    • Slide the lock switch to the right.
    • The panel will pop open at the top corner.
  3. HP Pavilion dv6-6180us Hard Drive  Replacement: passo 3, immagine 1 di 1
    • Use the plastic opening tool to remove the back panel.
    • Some force may be required to remove the panel from the case. Use caution when prying to avoid breaking the panel or the plastic tabs securing it in place.
  4. HP Pavilion dv6-6180us Hard Drive  Replacement: passo 4, immagine 1 di 1
    • Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
  5. HP Pavilion dv6-6180us Hard Drive  Replacement: passo 5, immagine 1 di 1
    • Lift the corner bracket to remove the hard drive.
  6. HP Pavilion dv6-6180us Hard Drive  Replacement: passo 6, immagine 1 di 1
    • Unplug the hard drive wire to detach the hard drive.
Conclusione
Altre 5 persone hanno completato questa guida.
CSU Fullerton, Team 1-2, Bruce Fall 2016 Membro di CSU Fullerton, Team 1-2, Bruce Fall 2016
CSUF-BRUCE-F16S1G2
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,796
