Salta al contenuto principale
HP Pavilion dv6-6117dx WiFi Adapter Replacement
Cosa ti serve
  1. HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: passo 1, immagine 1 di 2 HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: passo 1, immagine 2 di 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 2, immagine 1 di 2 HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 2, immagine 2 di 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 3, immagine 1 di 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 3, immagine 2 di 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 3, immagine 3 di 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 4, immagine 1 di 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 4, immagine 2 di 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 4, immagine 3 di 3
    • Using a spudger, remove the white and black antenna wires from the WiFi Adapter
    • When connecting these wires later, line up the connector and press straight down until you feel them snap in place.
  5. HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 5, immagine 1 di 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 5, immagine 2 di 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 5, immagine 3 di 3
    • Using a Phillips #0 screw driver, remove the two 4mm screws holding the WiFi adapter in place
    • After the screws are removed the WiFi Adapter will raise to a 45º angle.
  6. HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 6, immagine 1 di 2 HP Pavilion dv6-6117dx WiFi Adapter Replacement: passo 6, immagine 2 di 2
    • Always handle the WiFi Adapter by the edges to avoid damaging the part.
    • Pull the WiFi Adapter out of the slot at a 45º angle.
    • When inserting the new WiFi Adapter, you should insert it at this same angle.
Conclusione
Altre 2 persone hanno completato questa guida.
Joshua Holme
Membro da: 03/19/18
765 Reputazione
4 Guide realizzate
Un commento
Thanks i need to replace the wifi adapter in an old pc of mine,looks pretty simple.
pturner14 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,270
