Salta al contenuto principale
HP Pavilion dv6-6117dx RAM Replacement
Cosa ti serve
  1. HP Pavilion dv6-6117dx RAM Replacement, RAM: passo 1, immagine 1 di 2 HP Pavilion dv6-6117dx RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx RAM Replacement: passo 2, immagine 1 di 2 HP Pavilion dv6-6117dx RAM Replacement: passo 2, immagine 2 di 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx RAM Replacement: passo 3, immagine 1 di 3 HP Pavilion dv6-6117dx RAM Replacement: passo 3, immagine 2 di 3 HP Pavilion dv6-6117dx RAM Replacement: passo 3, immagine 3 di 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx RAM Replacement: passo 4, immagine 1 di 2 HP Pavilion dv6-6117dx RAM Replacement: passo 4, immagine 2 di 2
    • Push the tabs on both sides away from each other to free the RAM, which will raise to a 45º angle.
  5. HP Pavilion dv6-6117dx RAM Replacement: passo 5, immagine 1 di 2 HP Pavilion dv6-6117dx RAM Replacement: passo 5, immagine 2 di 2
    • Always handle RAM by the edges to avoid damaging the part.
    • Remove the RAM by grabbing it by the sides and pulling out at a 45º angle.
    • When inserting the new stick of RAM, you should insert it at this same angle.
Conclusione
Joshua Holme
Membro da: 03/19/18
765 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 737
