Salta al contenuto principale
HP Pavilion dv6-6117dx Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 2, immagine 2 di 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 3, immagine 1 di 3 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 3, immagine 2 di 3 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 3, immagine 3 di 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 4, immagine 1 di 3 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 4, immagine 2 di 3 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 4, immagine 3 di 3
    • Using a Phillips #0 screw driver, remove the four 4mm screws holding the hard drive in place.
  5. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 5, immagine 1 di 3 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 5, immagine 2 di 3 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 5, immagine 3 di 3
    • Using a plastic spudger, lift up the hard drive from the top left corner and flip it to the right of the laptop like opening a book.
    • There is a cable connecting the hard drive to the laptop, be sure not to pull it out when flipping the hard drive.
  6. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 6, immagine 1 di 2 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 6, immagine 2 di 2
    • Pull the tab at the end of the cable connecting the hard drive to the laptop.
  7. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 7, immagine 1 di 3 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 7, immagine 2 di 3 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 7, immagine 3 di 3
    • Using a Phillips #0 screw driver, remove the four 4mm screws on each side of the hard drive attaching it to its carriage.
  8. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 8, immagine 1 di 2 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 8, immagine 2 di 2
    • Remove the hard drive from its carriage.
  9. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 9, immagine 1 di 2 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 9, immagine 2 di 2
    • Remove the SATA cable from the hard drive.
Conclusione
Altre 4 persone hanno completato questa guida.
Joshua Holme
Membro da: 03/19/18
765 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 44
Tutti i Tempi: 2,536
