Salta al contenuto principale
HP Pavilion dv6-2158nr Speaker Assembly Replacement
Cosa ti serve
  1. HP Pavilion dv6-2158nr Speaker Assembly Replacement, Battery: passo 1, immagine 1 di 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Battery: passo 1, immagine 2 di 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Battery: passo 1, immagine 3 di 3
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. HP Pavilion dv6-2158nr Speaker Assembly Replacement, Keyboard: passo 2, immagine 1 di 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Keyboard: passo 2, immagine 2 di 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Keyboard: passo 2, immagine 3 di 3
    • Using a Philips #1 Loosen the three 7mm captive screws that secure the memory module compartment cover to the computer.
    • Lift the rear edge of the cover, swing it up and to the front, and remove the cover.
  3. HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 3, immagine 1 di 2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 3, immagine 2 di 2
    • Loosen the two 6mm captive screws that secure the hard drive port bezel cover to the computer, using a Philips #1.
    • Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover.
  4. HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 4, immagine 1 di 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 4, immagine 2 di 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 4, immagine 3 di 3
    • Use the Mylar tab to lift the hard drive up, and then slide it to the left to release it from the hard drive bay.
  5. HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 5, immagine 1 di 2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 5, immagine 2 di 2
    • Disconnect the hard drive cable from the system board.
    • Remove the hard drive from the hard drive bay and set it aside.
  6. HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 6, immagine 1 di 2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 6, immagine 2 di 2
    • With laptop upside down locate the three sets of screws that fasten the keyboard and switch cover.
    • Two Phillips 7mm screws that secure the switch cover to the computer.
    • Four Phillips 4.0mm screws that secure the switch cover to the computer. (these are inside the battery bay)
    • Four Philips 7mm screws that secure the keyboard to the computer.
    • Remove all ten screws.
  7. HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 7, immagine 1 di 2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 7, immagine 2 di 2
    • Turn the computer over, and locate the Switch Cover.
    • Using the Safe Pry Tool, un-clip the Switch Cover until it detaches from the computer.
    • The clips will need careful prying to unhook.
  8. HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 8, immagine 1 di 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 8, immagine 2 di 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 8, immagine 3 di 3
    • Slide the Switch Cover onto the LCD Monitor, exposing the Speaker Assembly.
    • There are two ribbon cables still attached to the speaker assembly
    • Detach the two ribbon cables from the speaker assembly.
  9. HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 9, immagine 1 di 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 9, immagine 2 di 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 9, immagine 3 di 3
    • Remove the three silver Phillips 3.5mm screws that secure the keyboard to the computer.
    • Lift the rear edge of the keyboard and slide the keyboard back until the keyboard connector on the system board is accessible.
  10. HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 10, immagine 1 di 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 10, immagine 2 di 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 10, immagine 3 di 3
    • Unhinge the zero insertion force (ZIF) connector to release the ribbon cable then pull gently on the cable to release.
    • You need to unhinge the blue plastic to release the ribbon cable from the main board.
    • The keyboard can now be lifted off and set aside.
  11. HP Pavilion dv6-2158nr Speaker Assembly Replacement, Speaker Assembly: passo 11, immagine 1 di 2 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Speaker Assembly: passo 11, immagine 2 di 2
    • Position the computer with the keyboard facing up its front edge toward you.
    • Disconnect the speaker cable from the system board.
  12. HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 12, immagine 1 di 2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: passo 12, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove the four Phillips 4mm screws that secure the speaker assembly.
    • You will also need the Phillips #1 screwdriver to remove the Phillips 7mm screw that secures the center of the speaker assembly.
    • Remove the speaker assembly from the computer.
Conclusione
Altre 2 persone hanno completato questa guida.
Chad
Membro da: 01/13/14
1.123 Reputazione
6 Guide realizzate
Cal Poly, Team 10-34, Maness Winter 2014 Membro di Cal Poly, Team 10-34, Maness Winter 2014
CPSU-MANESS-W14S10G34
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,916
