Introduzione
In this guide, you will learn how to disassemble your computer to access the TouchPad button. HP Spare Part Number 518789-001 for the top cover.
Cosa ti serve
Shut down the computer and unplug it from the outlet.
Disconnect the power supply cord from the side of the laptop.
Remove the two memory modules by spreading apart the two silver retaining tabs, using your thumb and index finger. Pull and lift the green memory module upward at a 45-degree angle, then pull the memory module out of the computer.
Repeat for the second memory module located directly underneath the first.
Lift up the yellow tape attached to reveal the webcam/microphone cable. Release the cables from under the grey clip built in to the top cover by gently pushing them away with the spudger.
Use the flat end of the spudger to detach the silver webcam/microphone cable from the system board by pulling the white connector away from the system board.
Now that the top cover is removed, check for debris or food particles that may have become trapped underneath the top cover's TrackPad button area.
Optional: Use compressed air to clean out dust and debris.
If the TrackPad button is broken, you will need to replace the entire top cover piece purchase and install HP spare part number 518789-001.
Altre 6 persone hanno completato questa guida.
