Introduzione
If your memory is full or having memory problems, then you can easily replace the RAM.
Prerequisties:
Remove the battery and the Hard drive before starting this guide.
Cosa ti serve
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Remove the two 5mm Phillips screws on the right side of the RAM cover.
Lift the right side of the RAM cover, and remove it.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Release the RAM by pressing the metal heads of the RAM clips to the sides. Use tweezers and the spudger to spread the clips until they are completely off the RAM.
Altre 2 persone hanno completato questa guida.
