Salta al contenuto principale
HP Pavilion dv4000 Keyboard Replacement
Cosa ti serve
  1. HP Pavilion dv4000 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop upside down with the battery compartment facing you.
    Chiedi a FixBot
  2. HP Pavilion dv4000 Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide the battery release latch to the right and hold in place.
    Chiedi a FixBot
  3. HP Pavilion dv4000 Keyboard Replacement: passo 3, immagine 1 di 1
    • Lift the front edge of the battery up and remove it from the compartment.
    Chiedi a FixBot
  4. HP Pavilion dv4000 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
    • Have your device open in front of you for easy access to the keyboard.
    Chiedi a FixBot
  5. HP Pavilion dv4000 Keyboard Replacement: passo 5, immagine 1 di 1
    • Using a metal spudger, pry up on the plastic piece above the keyboard containing the power button.
    • Be careful not to damage any components with the tool while prying.
    Chiedi a FixBot
  6. HP Pavilion dv4000 Keyboard Replacement: passo 6, immagine 1 di 1
    • Lift the plastic piece up.
    • When lifting this piece, be careful not to damage the ribbon strip connected to it.
    Chiedi a FixBot
  7. HP Pavilion dv4000 Keyboard Replacement: passo 7, immagine 1 di 3 HP Pavilion dv4000 Keyboard Replacement: passo 7, immagine 2 di 3 HP Pavilion dv4000 Keyboard Replacement: passo 7, immagine 3 di 3
    • Place the plastic piece on the keyboard so the ribbon strip is easily accessible.
    • Carefully disconnect the ribbon strip from the keyboard by pressing on the tabs at the edges.
    • Remove plastic piece and set aside.
    Chiedi a FixBot
  8. HP Pavilion dv4000 Keyboard Replacement: passo 8, immagine 1 di 1
    • Locate the four 2x2 mm screws that hold the keyboard in place.
    Chiedi a FixBot
  9. HP Pavilion dv4000 Keyboard Replacement: passo 9, immagine 1 di 1
    • Unscrew the four 2x2 mm screws with a #00 Phillips screwdriver.
    Chiedi a FixBot
  10. HP Pavilion dv4000 Keyboard Replacement: passo 10, immagine 1 di 2 HP Pavilion dv4000 Keyboard Replacement: passo 10, immagine 2 di 2
    • Lift the keyboard up.
    • When lifting the keyboard, be sure not to damage the ribbon strip that is connected to it.
    Chiedi a FixBot
  11. HP Pavilion dv4000 Keyboard Replacement: passo 11, immagine 1 di 1
    • Locate where the ribbon strip is connected to the motherboard.
    Chiedi a FixBot
  12. HP Pavilion dv4000 Keyboard Replacement: passo 12, immagine 1 di 2 HP Pavilion dv4000 Keyboard Replacement: passo 12, immagine 2 di 2
    • Pry at the edges of the plastic clip holding the ribbon cable to the motherboard.
    • Be careful during this step as these clips are very easy to break.
    Chiedi a FixBot
  13. HP Pavilion dv4000 Keyboard Replacement: passo 13, immagine 1 di 3 HP Pavilion dv4000 Keyboard Replacement: passo 13, immagine 2 di 3 HP Pavilion dv4000 Keyboard Replacement: passo 13, immagine 3 di 3
    • Remove the keyboard.
    Chiedi a FixBot
Conclusione
UMass Dartmouth, Team 4-2, Catania Fall 2016 Membro di UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,205
