Salta al contenuto principale
HP Pavilion dv4000 CD/DVD drive Replacement
Cosa ti serve
  1. HP Pavilion dv4000 CD/DVD drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 CD/DVD drive Replacement: passo 2, immagine 1 di 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 CD/DVD drive Replacement: passo 3, immagine 1 di 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 CD/DVD drive Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Orient the laptop with the hard drive panel towards you.
  5. HP Pavilion dv4000 CD/DVD drive Replacement: passo 5, immagine 1 di 1
    • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000 CD/DVD drive Replacement: passo 6, immagine 1 di 2 HP Pavilion dv4000 CD/DVD drive Replacement: passo 6, immagine 2 di 2
    • Lift the cover up by the tab near the screws.
    • The cover can be removed from the laptop.
  7. HP Pavilion dv4000 CD/DVD drive Replacement: passo 7, immagine 1 di 1
    • Grab the hard drive from the sides and slide it away from the connectors.
    • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
    • Lift and remove the hard drive from the laptop.
    • We did not have a hard drive in our laptop to demonstrate how to remove it.
  8. HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: passo 8, immagine 1 di 2 HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: passo 8, immagine 2 di 2
    • Locate the one 2x5 mm screw in the hard drive bay.
    • Unscrew the screw with a #00 Phillips screwdriver.
  9. HP Pavilion dv4000 CD/DVD drive Replacement: passo 9, immagine 1 di 3 HP Pavilion dv4000 CD/DVD drive Replacement: passo 9, immagine 2 di 3 HP Pavilion dv4000 CD/DVD drive Replacement: passo 9, immagine 3 di 3
    • Locate the hole next to the DVD drive release button.
    • Insert a paperclip into the hole to release the DVD drive.
  10. HP Pavilion dv4000 CD/DVD drive Replacement: passo 10, immagine 1 di 2 HP Pavilion dv4000 CD/DVD drive Replacement: passo 10, immagine 2 di 2
    • Carefully grasp the DVD drive and slide it out.
Conclusione
Altre 4 persone hanno completato questa guida.
UMass Dartmouth, Team 4-2, Catania Fall 2016 Membro di UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,128
