Salta al contenuto principale
HP Pavilion dv4-4141us Optical Disc Drive Replacement
Cosa ti serve
  1. HP Pavilion dv4-4141us Optical Disc Drive Replacement, Back Panel: passo 1, immagine 1 di 1
    • Lift up the back panel using a spudger, and remove it from the device.
  2. HP Pavilion dv4-4141us Optical Disc Drive Replacement: passo 2, immagine 1 di 3 HP Pavilion dv4-4141us Optical Disc Drive Replacement: passo 2, immagine 2 di 3 HP Pavilion dv4-4141us Optical Disc Drive Replacement: passo 2, immagine 3 di 3
    • Using the Phillips #1 screwdriver unscrew the panel from the computer.
    • Lift the panel up and remove it from the laptop.
  3. HP Pavilion dv4-4141us Optical Disc Drive Replacement, Optical Disc Drive: passo 3, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the single screw securing the disc drive to the device.
  4. HP Pavilion dv4-4141us Optical Disc Drive Replacement: passo 4, immagine 1 di 1
    • Remove the disk drive by pulling out so that it can be replaced with a new one.
Conclusione
Jake Paris
Membro da: 10/25/21
252 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 79
