Salta al contenuto principale
HP Pavilion dv2913cl WiFi receiver Replacement
Cosa ti serve
  1. HP Pavilion dv2913cl WiFi receiver Replacement, WiFi receiver: passo 1, immagine 1 di 1
    • Begin by locating the smallest panel with one screw attaching it to the laptop computer.
  2. HP Pavilion dv2913cl WiFi receiver Replacement: passo 2, immagine 1 di 1
    • Remove the one screw holding the panel down, and the WiFi receiver will be revealed.
  3. HP Pavilion dv2913cl WiFi receiver Replacement: passo 3, immagine 1 di 1
    • Remove the two screws that hold down the receiver.
    • Gently slide the chip out of the socket.
  4. HP Pavilion dv2913cl WiFi receiver Replacement: passo 4, immagine 1 di 2 HP Pavilion dv2913cl WiFi receiver Replacement: passo 4, immagine 2 di 2
    • Remove the two wires labelled AUX and MAIN from the chip.
    • Remember where these were attached previously as it is important for proper functionality after the replacement.
Conclusione
Adam Braga
Membro da: 10/24/16
230 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 134
