Salta al contenuto principale
HP Pavilion dv2913cl RAM Replacement
Cosa ti serve
  1. HP Pavilion dv2913cl RAM  Replacement, Ram: passo 1, immagine 1 di 2 HP Pavilion dv2913cl RAM  Replacement, Ram: passo 1, immagine 2 di 2
    • Unscrew the two screws on the center panel of the device .
    • Then gently remove the center panel.
  2. HP Pavilion dv2913cl RAM  Replacement: passo 2, immagine 1 di 3 HP Pavilion dv2913cl RAM  Replacement: passo 2, immagine 2 di 3 HP Pavilion dv2913cl RAM  Replacement: passo 2, immagine 3 di 3
    • Gently push the silver clamps on both sides of the RAM stick on top.
    • Pushing the clamps back could damage the device. push far enough to remove the RAM card.
    • Now remove the RAM stick on top from the device.
  3. HP Pavilion dv2913cl RAM  Replacement: passo 3, immagine 1 di 3 HP Pavilion dv2913cl RAM  Replacement: passo 3, immagine 2 di 3 HP Pavilion dv2913cl RAM  Replacement: passo 3, immagine 3 di 3
    • Gently push the silver clamps on both sides of the bottom RAM stick.
    • Pushing the clamps back could damage the device. Push gently just far enough to remove the RAM stick.
    • Now remove the bottom RAM stick from the device.
  4. HP Pavilion dv2913cl RAM  Replacement: passo 4, immagine 1 di 1
    • this is the device with both RAM sticks removed.
Conclusione
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 85
