Salta al contenuto principale
HP Pavilion dv2913cl Keyboard Replacement
Cosa ti serve
  1. HP Pavilion dv2913cl Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Locate battery on the bottom of the laptop.
  2. HP Pavilion dv2913cl Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide the battery release bar to the left, this should release the battery so you can then remove it.
  3. HP Pavilion dv2913cl Keyboard Replacement: passo 3, immagine 1 di 2 HP Pavilion dv2913cl Keyboard Replacement: passo 3, immagine 2 di 2
    • Locate the three screws for the keyboard by finding the small keyboard picture, remove these screws and flip the laptop back over.
  4. HP Pavilion dv2913cl Keyboard Replacement: passo 4, immagine 1 di 1
    • Open the laptop so the keyboard is facing upwards and towards you.
  5. HP Pavilion dv2913cl Keyboard Replacement: passo 5, immagine 1 di 2 HP Pavilion dv2913cl Keyboard Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to get underneath the plastic bar above the keyboard, pry upwards. Pry the keyboard upwards gently.
    • Be careful not to pull the keyboard too hard so you do not rip the silver ribbon cable attached to the laptop.
  6. HP Pavilion dv2913cl Keyboard Replacement: passo 6, immagine 1 di 2 HP Pavilion dv2913cl Keyboard Replacement: passo 6, immagine 2 di 2
    • Release the ribbon cable by using a flathead screw driver. Release the two tabs holding the cable and pull outwards.
    • Pull the keyboard up and out from the laptop.
Conclusione
Adam Braga
Membro da: 10/24/16
230 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 143
