Salta al contenuto principale
HP Pavilion dv2700 Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion dv2700 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • To remove the battery, pull the tab to the left and lift the battery from the computer.
  2. HP Pavilion dv2700 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Using a #0 Phillips Head screwdriver, unscrew the hard drive cover.
    • The screws cannot be removed from the cover.
    • To remove the cover, lift up and to the left.
  3. HP Pavilion dv2700 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Using a #0 Phillips Head screwdriver, remove the screws holding the hard drive in place.
    • These are the two screws located on the right side of the hard drive.
  4. HP Pavilion dv2700 Hard Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion dv2700 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Lift the tab connected to the hard drive in order to remove it.
    • The hard drive may be difficult to remove by grabbing the tab. In this case, use the spudger to gently pry it from the computer.
Conclusione
Altre 2 persone hanno completato questa guida.
Texas Tech, Team 22-6, Rauch Fall 2015 Membro di Texas Tech, Team 22-6, Rauch Fall 2015
TTU-RAUCH-F15S22G6
3 Membri
2 Guide realizzate
Un commento
Hi, I have a seagate hard drive that was mounted on a hp pavillon dv series computer. I only have the hard disk and I can not find any serial adapter that can be connected to the hard disk connector. I saw on amazon and ebay but I did not find anything. Can you help me? Thank you!
L. S. - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,061
