Introduzione
This guide will help you replace the wireless card on you HP Pavilion dv2000.
Cosa ti serve
Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
Lift up and remove the wireless card casing.
Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
Gently pull out your wireless card from its top side to remove it from its holding.
Altre 3 persone hanno completato questa guida.
