Salta al contenuto principale
HP Pavilion dv2000 Wireless Card Replacement
Cosa ti serve
  1. HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: passo 1, immagine 1 di 2 HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: passo 1, immagine 2 di 2
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
    • Lift up and remove the wireless card casing.
    • The 3.8mm screw will remain in the wireless card casing after you unscrew it.
  2. HP Pavilion dv2000 Wireless Card Replacement: passo 2, immagine 1 di 2 HP Pavilion dv2000 Wireless Card Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of tweezers to remove the three antennas from their sockets.
    • Remove the antennas by the contacts connected to the socket, the crimps connecting the wires and the sockets are delicate and are easily damaged.
  3. HP Pavilion dv2000 Wireless Card Replacement: passo 3, immagine 1 di 3 HP Pavilion dv2000 Wireless Card Replacement: passo 3, immagine 2 di 3 HP Pavilion dv2000 Wireless Card Replacement: passo 3, immagine 3 di 3
    Phillips #00 Screwdriver
    $5.49
    Compra
    • Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
    • Gently pull out your wireless card from its top side to remove it from its holding.
Conclusione
Altre 3 persone hanno completato questa guida.
Erik Muniz
Membro da: 09/09/14
820 Reputazione
3 Guide realizzate
CSU Fullerton, Team 2-3, Bruce Fall 2014 Membro di CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,235
