Salta al contenuto principale
HP Pavilion dv1000 RAM Replacement
Cosa ti serve
  1. HP Pavilion dv1000 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 RAM Replacement: passo 2, immagine 1 di 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 RAM Replacement: passo 3, immagine 1 di 2 HP Pavilion dv1000 RAM Replacement: passo 3, immagine 2 di 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 RAM Replacement: passo 4, immagine 1 di 3 HP Pavilion dv1000 RAM Replacement: passo 4, immagine 2 di 3 HP Pavilion dv1000 RAM Replacement: passo 4, immagine 3 di 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
    I bought it old but its camera & bluetooth is not working what can be done
    jagannath dey - Replica
  5. HP Pavilion dv1000 RAM Replacement, RAM: passo 5, immagine 1 di 1
    • Locate RAM access door on the bottom side of the laptop.
  6. HP Pavilion dv1000 RAM Replacement: passo 6, immagine 1 di 3 HP Pavilion dv1000 RAM Replacement: passo 6, immagine 2 di 3 HP Pavilion dv1000 RAM Replacement: passo 6, immagine 3 di 3
    • Locate the two screws holding down the RAM access cover
    • Unscrew the two screws with a size 00 Philips screwdriver.
    • Note: The screws do not detach from the cover.
  7. HP Pavilion dv1000 RAM Replacement: passo 7, immagine 1 di 2 HP Pavilion dv1000 RAM Replacement: passo 7, immagine 2 di 2
    • Lift up on the screw side of the RAM access cover to remove it.
  8. HP Pavilion dv1000 RAM Replacement: passo 8, immagine 1 di 2 HP Pavilion dv1000 RAM Replacement: passo 8, immagine 2 di 2
    • Gently pull apart the metal tabs located on both sides of the stick of RAM.
    • The RAM stick should tilt upwards.
  9. HP Pavilion dv1000 RAM Replacement: passo 9, immagine 1 di 1
    • Gently lift the the RAM up and out of its seat.
  10. HP Pavilion dv1000 RAM Replacement: passo 10, immagine 1 di 1
    • Repeat the previous two steps for the remaining stick of RAM.
Conclusione
Altre 5 persone hanno completato questa guida.
Henry OBrien
Membro da: 04/04/11
104 Reputazione
1 Guida realizzata
Cal Poly, Team 10-37, Forte Spring 2011 Membro di Cal Poly, Team 10-37, Forte Spring 2011
CPSU-FORTE-S11S10G37
5 Membri
9 Guide realizzate
2 Commenti
THANKS - YOU'RE AWESOME!!!! Removing the hard drive was the fix it! the HP site never tells you this - imagine.......
marena - Replica
I had never dealt with laptop ram before and i used this guide sussusfully to remove the ram from my old HP Pavilliondv6-3055dx laptop. Thanks!
Andrew Lonero - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 8,884
